Question about TORK Timer 1 Channel Signal Timer Dgs100
The TORK 1001 Timer stops at the end of the cycle? and do not advance after it stops the lights. Any solution?
  • TORK Master
  • 5,391 Answers
Hello Tarsem
To repair this problem, replace and install new Tork 101 clock motor on back of timer:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Also order new trippers.
Add comment
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 06, 2013
6ya staff
SOURCE:
The tork 1001 time stop at the end of the cycle? any solution?
Replace and install new Tork 101 clock motor on back of timer:
Gene
Aug 06, 2013 | Hardware & Accessories
How tio wire a tork model ejwt timer
Tork EJWT is percentage cycle timer that was formerly manufactured by Paragon and sold as the Paragon E500 series interval (cycle) timer
Copy following link for clear Tork EJWT wiring illustration
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle-timer
Jul 18, 2012 | TORK Digital Interval Timer Ssa100r-24
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
I have lost the tabs for stopping and starting on the wheel can anyone help
http://www.fixya.com/postanswer.aspx?thid=7727746&prdid=977752&ctgid=307&ref=unslt
1) You posted under TORK Variable Cycling Timer 8601
This particular timer has built-in trippers.
Sample manual for this type of timer describes tripper operation:
http://waterheatertimer.org/pdf/8602INSTALLOP.pdf
2) You can see Tork trippers at following link.
Page also shows Tork timers so you can identify your timer for certain.
http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) If you have a different brand timer, the particulars will show on inside of door.
4) Add a comment your brand and model number for more free help.
I will find a source for your tripper, unless you have Paragon brand, in which case the trippers are no longer being made, and you may need a new timer.
5) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | TORK Variable Cycling Timer 8601
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I need a plug-in timer that I can turn something ON for 5 minutes every hour. What can you suggest? Henry
You need a 60 minute cycle timer capable of running 12 cycles per hour.
Usually this type of timer is heavier duty for commercial applications like garden irrigation or misting, stock feeding, or cattle barn ventilation. Commercial applications require reliable long-term product with higher price.
Average mass market plug-in timer is lighter duty, and is used for turning on indoor lamp or outdoor christmas lights a few times per day. These timers are inexpensive 'corner store' items priced at 6-15$. There would be no mass market for for a plug-in cycle timer as specific as your requirement.
Intermatic makes a panel-mount digital cycle timer you could wire to short extension cord.
http://www.intermatic.com/products/grasslin/electromechanical
Tork ACT cycle timer is less precise, but could be wired to short extension cord:
http://www.google.com/products/catalog?q=tork+cycle+timer
Tork sell sheet & wiring
At grainger\
https://www.grainger.com/Grainger/cycle-timers/timers/act
Sep 07, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Timer start at desired time wand won't stop at set time
Open following link to identify Tork timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Add a comment and say exactly what timer you have, and include photo of your timer and wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Aug 12, 2009 | TORK Variable Cycling Timer 8601
I'm trying to find a users manual to reset my timer.Our recent manual has been misplaced thru the years.I did the reset,but still no lights on at syncronized time...anybody?help?
Add a comment and include photo of your timer and wiring.
Apr 14, 2009 | TORK Variable Cycling Timer 8601
TORK Timer 1 Channel Signal Timer Dgs100 Logo
101 people viewed this question
Top TORK Hardware & Accessories Experts
Thomas F. Schneider
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
