Olympus VN-3100PC Digital Voice Recorder Logo
Anonymous Posted on Aug 06, 2013
I bought a new digital Voice Recorder GH518 through Ebay, great, except only half the instructions with it!! Any suggestions. Seller ozlocalstore, My buyer NO. jgra2822.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jun 01, 2008
SOURCE: Olympus VN-3100PC Digital Voice Recorder "Err" Message
Download the digital wave player and install it. That will work for your VN-3100PC http://www.olympus.it/consumer/2590_software.cfm?category=0&productgroup=347&product=421&os=7&result=
Anonymous
  • Posted on Nov 21, 2008
SOURCE: w10 olympus digital voice recorder
i want to transfer my files from my
W10 olympus digital voice recorderto my p.c but i dont have the cd-rom for the installation of the programme. i WOULD APPRECIATE ANY HELP
Thanx!
Anonymous
  • 919 Answers
  • Posted on Dec 10, 2008
SOURCE: Digital Voice Recorder VN-3100PC transer from PC back to recorder
With this particular model of recorder that functionality is not possible as when the recorder is connected to the computer it is not a USB Mass Storage Device. It will only files to be downloaded to the computer not uploaded back.
Anonymous
  • Posted on Mar 10, 2009
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
I called the number and here is the link that has the software and drivers.
http://www.olympusamerica.com/files/digitalwaveplayer.zip
Anonymous
  • 919 Answers
  • Posted on Mar 23, 2009
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
2answers
Does anyone know where I can buy one these recorders?
Do a Google search of "Panasonic RR-DR60 Handheld Digital Voice Recorder" and you'll find several online shops selling that recorder, either in USA or in UK.
Assuming you are in the USA, start by going to in Amazon.com.
Also, see these other merchants that carry that model
I bought an Olympus DS 40 from ebay - ie wothout
open the battery compartment there is a very small white sticker that has your serial number hard to read but it is there enjoy!
4helpful
Where can I get manual for Marantz PMD-221
I have manuals for the Marantz PMD 201/PMD221 and the 420/430.
Michael
Problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
The slide switch on my Olympus DS-4000 digital dictation recorder is too sensitive, and often goes to the "Record" position when it should be "Off." Any suggestions in how to correct...
The slide switch on your Olympus DS-4000 probably needs to be replaced. You can ship it to PCDictate.com to have your Olympus DS-4000 repaired. The repair will most likely run around $100,
However, my suggestion is that you upgrade to the Olympus DS-5000 digital voice recorder, the replacement for the DS-4000. It is a substantial upgrade and you will not regret it.
If you want to consider another brand, Philips has some great digital voice recorders. My favorite models are the Philips LFH-9600 and Philips LFH-9500 professional digital voice recorder.
The best place to purchase professional digital voice recorders is PCDictate.com. Your recorder will be shipped the same day your order and shipping is free.
10helpful
2answers
DS-2 Olympus Digital voice recorder
You can buy the disk but there is a download. DSS Player (version 7.0): is available via download as a courtesy, please follow the instructions below: http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
Serial #:(8360-0101-0027-7420-4735 )
Low sound quality, lot's of noise
the recorder does have two mic settings, hi and low. the high is great for lectures and the low is for personal dictation
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
