I just bought an Armani AR5331 watch with chronograph. It has 3 dials within the face, one of which is the second hand. The other two are the minute and hour dials for the stopwatch function. The second hand on the actual face is for the stopwatch. When you reset the stopwatch the second hand resets to zero but the minute and hour dials don't and there is no useful information in the manual! Does anyone know how to manually reset them to zero or do you think there is a fault with the watch? Thanks. I have an Armani AR5331 and when I reset the stopwatch, it goes to the #2 instead of the 12. I have no manual. It is second hand and was a gift. Any ideas?
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Very usefle. works for my tissot PRC200
Modified works on Timex T49824. Thanks! If you pull the crown halfway out (6 o'clock not needed), you can set zero with 4 o'clock button for chronograph minutes. If you pull it all the way out, you can set zero for cronograph seconds with 2 o'clock button and zero for 1/20 of second with 4 o'clock button.
SOURCE: Resetting stopwatch dials - Armani AR5331
The 24 hour face on the right of the watch is the time, not the stop watch. The minute timer on the left of the watch face is the minutes for the stopwatch, if this is not resetting to 0 after holding down the lower button on the right hand side of the watch, contact your manufacturer.
Second hand on my Giorgio Armani AR-0534 is stuck
Second hand stuck on my armani watch
