I have a AVA 106cm Plasma TV (AWA CP-42PDH10S) & a AWA 5.1 Home Theater System (with dvd) (AWADA646PA) . First tried to connect with cables supplied, then purchased Platinum cables (red, blule & green), then purchased s video cable. The best I can get is surround sound on DVD and Analogue TV, nothing on HD TV. Can anyone help??
SOURCE: Too many Cables??
Firstly, let me address audio cables. Optical audio is the same (essentially) as a coaxial digital audio cable, just in a different form. Since you just purchased a Bluray player, you'll see an HDMI out on the rear. This is a high definition video and audio cable rolled into one (however it looks like your receiver does not support this). I would recommend running an HDMI cable from the Bluray player right to the TV, then run an optical audio cable (or coaxial digital) from the TV to the receiver. This will give you the best picture on your TV, and the best available sound through your receiver.
Depending on your DVD player and Bluray player, you might want to consider using just the Bluray player for DVD's and Bluray discs. If your plasma supports 1080p (or really anything better than 480i), you would most likely get a better picture out of DVD's since the Bluray player will upconvert the video to the better signal (of course this depends on your exact model of Bluray player). This will help to eliminate some cabling also.
Other than that, you're not going to eliminate much more cabling. If you really want to get tricky with it, pick up some split loom wire management and wrap them up with that. Be sure to run the power and signal wires separately though! Best of luck, and hope this has helped.
SOURCE: Panasonic HDMI surround system problem
The HDMI cable connection on your system is a video out to your TV.
To get audio from the TV so you can hear it through the system, you need to add a cable from the audio out of your TV to the "aux" input on the panasonic system.
This is most likely a red and white connection which will give you stereo, or pro-logic surround from the home theater system.
SOURCE: advise on how to wire tv home entertainmet dvd hdi cable together
hdmi is the least amount of cables you'd need to run, 1 cable for audio & video for each device, assuming they have hdmi outputs on them and you have enough inputs on your tv.
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
SOURCE: Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
