Question about Avanti W789SA Top Load Washer
Avanti spinning problem
Mine is Avanti W798 and I bought it about two months ago. For the first two weeks, it works well, but after that it has spinning problem. When I go with Automatic Program, it washes and rinses, but keeps agitating without spinning. I checked the belt at the bottom of the machine, and it looked fine to me. (After all, it is a two months old brand-new machine, for god's sake!!!)
Yet, when I turn off the machine and re-turn it on about 30 minutes later (when the machine is totally cooled down) and choose the spinning course only, it starts agitating and then spins!!!
So, what do you think the problem is? Do I load too much clothes? Balance problem (I use it as a portable, so I did not set the balance minutely)? Or, other mechanical problem like motor overload?
Please advise me.
    Sergeant:
  • 378 Answers
One of the largest problems with this washer has been the lid switch, you must check it out with a ohm meter, if the switch quits you will lose power to the motor. Things can get caught between the tanks as well, this machine is bad for the center bearing tightening up and the spin will quit. This is a new close up pictureof a typical lid switch. You can temporarily join the wires together to test the motor and washer operations.
Posted on Apr 03, 2009
6ya staff
SOURCE:
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Hi! I purchesed washer mashine Avanti W798SS a few month ago and I have a problem with that- It fill the water and after that in washer regimen it doesnt operate- there is no moving- it shows error sign. I...
If it's still under warranty. Go to the store where you bough from
and ask them about. They'll ask an authorize from the factory and the will find some one to fix for you.
Good luck
Mai
May 16, 2017 | Avanti (WDE79BSS)
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
Hello i have a nissan pulsar n13 i bought it about two months ago and has a faulty water temp gauge i had it going bya mechanic until last week when i replaced the lights in the cluster and now the temp...
possibly the circuit board but i see it unlikely. you may have damaged a wire that works the temp guage. i have a nissan pulsar and mine works just fine.
Dec 23, 2008 | Nissan Pulsar Cars & Trucks
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Player problem connect to pc??
i bought mine a few weeks ago and its not connecting to my pc
my copmuter is not even reading it
Nov 08, 2007 | Philips SA1100 MP3 Player
Problem with portable dvd player
i would return the item to your retailer as it should hold a 12 month warranty, as if it cannot read cds or dvd, the lens is faulty, and trying to repair it yourself will void your warranty. Please dont forget your ratings are important, thank you
Jun 05, 2007 | Dynex DX-DVDR100 (DXDVDR100) Internal DVD...
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Avanti W789SA Top Load Washer Logo
384 people viewed this question
Top Avanti Washing Machines Experts
Ekse
Archie Ferrarini
Archie Ferrarini
ray gallant
ray gallant
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
