Anonymous Posted on Aug 06, 2013
How to reset epson t 60 printer - Stylus Epson Office Equipment & Supplies
Martin Smallridge
Level 3:
  • Epson Master 419 Answers
  • Posted on Aug 06, 2013
Martin Smallridge
Epson Master
Level 3:
Answers
419
Questions
0
Helped
289780
Points
1120
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
7helpful
6answers
How to reset epson t60
epson t 60 ganral errer slootion
1helpful
2answers
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
1helpful
Blinking power button after new cartridge install
the SCC Epson Service Utility
Version 3.10 from:
http://inkjetprinterhelp.us/epsonSSC.html
and it works!!!!!!!!!!
SSC Service Utility allow You to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Freeze internal ink counters.
3) Reset internal ink counters even with empty cartridges.
4) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
5) Hot swapping of cartridges supported.
6) Resetting of protection counter (even then it is already full).
7) More then 60 different Epson printers supported
Says internal parts are beyond service date .
No need code to reset. just find resetter at indoreset.blogspot.com. Be sure to clean the waste pad first
2helpful
2answers
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
Printing text is all I do and have a new black cartridge in
hi,
one way to start to start the reset process is to unplug the two cords from the back ot the printer, the power and the other one, wait 60 seconds, and plug them back in. Then click on ...file....page setup....printer....properties...from the menus on your browser. It is in that last menu where you can setup whether to print in color or just black and white. Change your setting. Click done and exit. Try to print some thing. I hope this helps.
Printer
Hey patty815 I own 7 (C-60 printers) and I'm always looking for more.These are excellant printers if you don't over think when you are working on one. You can get a C-60 Icon (to press) by doing this; Press start...Press Printers and Faxes...Press your left mouse button on the picture of the printer and hold it down while you drag it to anywhere on your Desktop...and release. You should have an Epson Icon on your desktop now. ALSO: try pressing your Right mouse button on the Icon to learn a lot more stuff about the C-60. I hope this helps. Dave
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
