Hi there I have a Uniden cordless phone I think DECT12035 but my manual lists 2 other models DECT 12035+1 and DECT 12035+2. When I press Talk I get a beeping sound in the ear piece. There are no messages. Also, I want to clear the CID on my home screen, how do I do this? Tx Lu
SOURCE: Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can Conference call You can hold a 3-way conversation (conference call) between your handset, an external caller and another internal handset user. During an external call: 1 Press . The external caller is put ?on-hold?. 2 Press or to select name, number or the handset you want to have a conference call with and press or key. The called handset will ring. 3 When the called handset answers, press to start your conference call. 4 Any handset can press at any time to leave the conference call. It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for. Please repost with any other comments or questions. Please rate this solution through fix-it. Thank you.
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
SOURCE: Need Manual For Uniden Cordless Telephone Model #
You can download the instruction manual in PDF format by clicking this link.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: Need Owner's Manual for Uniden Cordless Phone Model 2180-3
Here is the link. to a pdf version of the phone manual.
