Garden Logo
Posted on Apr 03, 2009
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Craftsman CRT 4hp 14 inch.
makes loud shrill squealing noise when tilling.
Noise comes and goes, sounds like metal on metal, not a belt squealing.
Cant push easily in nuetral with engine off.
Gears make grinding noise, wheels wont turn.
Robert Frost
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on Jul 23, 2014
Robert Frost
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
9
Questions
0
Helped
3817
Points
11
Sometimes the pull start rope clutch gets stuck. It has 5 or six ball bearings in that pull away from the starting clutch by cintrifical force after motor starts. If one get suck it keeps the start clutch spinning. Easy fix. take Top cowling off remove wire mesh screen off and pop lid off clutch. Youll see the ball bearings. see if their rusted. Clean and replace in revirse order. good luck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 06, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1856
Points
0
Noise comes and goes sound like metal on metal not a belt squealing
1 Related Answer
Anonymous
  • 623 Answers
  • Posted on May 26, 2010
SOURCE: Bought a new tiller and no manual, could I print
See if these website folks can help you...
http://community.craftsman.com/Craftsman-14-In-Rear-Tine-Tiller-reviews?tab=details
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ā€Ž1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES Ā· 2008 Lancer GTS no start please ... 2011 lancer no sound Ā· Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot Ā· Very loud noise on Lancer ES 2008 ...
98 ford explorer makes loud squealing noise when i start i have replaced belt and pulley
usually the squeal because the belt is'nt tight enough push on it , check the deflection---no more than 1/2 inch, i like 1/4 in.....hope this helps
11helpful
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Dyson DC14 Loud shrill whistle noise
Check and cleaning Brushbar Assy and Violet Cyclone Assy or replaced Brushbar Assy and Clutch Assy
1helpful
I have craftsmen 5HP rear tine tiller,while tilling picked up a rock which jammed the tines and stalled the motor. when i restarted it had loud grinding noise and then locked up stopping me from being able...
If the tiller tines where jammed, the tranny and motor where still trying to turn and there could be a couple different parts broken. The tranny main shaft make have busted, the tranny gears could have jammed. If the motor does start, than that is a good sign. If not than the connecting rod or crank may have snapped.
I am guessing you will probably have to dismantle the transmission and see if there are any broken gears or shaft.
4helpful
Loud squealing noise from dlp tv -50 inch samsung, modelHLN507W
your color wheel needs to be replaced the squealing noise are the bearings.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
