I am not able to open Memory Stick of Data Traveler 40 GB on windows XP& Old Vista. however the same is opening on latest windows vista.on older windows xp the moment i insert the memory stick it tells the disk needs to be formated.however the same is also not getting formated.
Dear,
You can do then please
!. Check the same Memory Stick on another PC (if possible then of same configuration as your PC)
2. Make sure your Pc has Updated antivirus.
If both are Ok then follow the steps
1.Backup the Memory Stick data on other PC.
2. Format the Memory Stick.
3. Paste the data back to the Memory Stick.
It will solve your problem.
Regards,
Rakesh Kumar
Hope this helps
Hope this helps you
