I was given a Motorola v551 but I can't get inside cause they lost the initial 4 digit unlock code. How do I fix or retrieve lost code?
SOURCE: UNLOCK CODES
Hi u can try 1234 or 0000 or 1111 if this not work then contact to your cell phone service provider. call to call center.
SOURCE: motorola v36o master unlock code
i also have the same problem i forgot my security code how do i find it with out any cost
SOURCE: what is the 4 digit default lock code or phone lock of motorola L6???...
please e mail me... [email protected] ....what is the default lock code of motorola L6.. im not talking about the 6 digits code or (000000)... example: when you want to lock the multimedia it requires 4 digit only... I already reset my phone.. (master clear and master reset) it requires the 6 digits code (000000).. I was expecting that the 4 digits code will be returned to default.. I tried (1234), (0000) and (1111 to 9999).. all I know is the default 6 digits code (000000) to reset my phone..
SOURCE: need master unlock code or master security code
Usually it can be accessed by entering six zero's unless the code was changed
Testimonial: "thanx but I have tried 000000, 1234, & last 4 digits of SS# and nothing worked"
SOURCE: i forgot unlock code of my motorola L6 phone....Is there any mast
if you have forgotten your unlock code, you should atleast remember the Security code.
When it asks you the unlock code, press the menu button(the line above the navigation keys) ... then it asks you for the security code, then enter the security code, if you dont know this also, try to enter the default security code as 123456 or 000000..
this works.
you can change the unlock code also by using this security code..
Narendra Tirunahari
