SOURCE: Computer Does Not turn On
Three things to look at. . .
1) CPU Heat Sink is full of 'House hold Dust - Clean it off !
2) If youre one to leave ur PC running 24/7 - 365 days a year -
The slightest bang, drop, jolt (See in you Theasaurus Bud) will shear the contact between the Proccessoe surface and the Heat Sink - Giving you zero Heat transfer - New Heat sink Grease !
3) Bung your Ram Module into the trash or the nieghbours roof, replace it ( it's the cost of a tube of toothpaste nowdays ) and if it still does work after allll that - Get your .357 Mag. out - Great target - seriously !!
SOURCE: Monitor stuck in Power Save Mode
yes look like your nvidia run out of juice you can look at nvidia 7200 le or maibe 8200 gs that will be a reasonable price / quality grafics cads for a upgrade of the 6800 thanks
SOURCE: my computer(a dell) is stuck on save power mode
The reason your computer is in power save mode is because the little battery inside your tower is going dead. It needs to be replaced. It is a small battery about the size of a nickle inside your tower. Change the battery and it will solve your problem.
SOURCE: Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Testimonial: "Will try when the monitor does this again. Was very helpful. Thanks!"
