SOURCE: Region codes for Samsung R155 (UK)
hi give this ago works fine on us or uk
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested and Worked on my UK player (Region 2).
also works on r136 and r150
SOURCE: multi region code for samsung dvd 5500
um there is a reason why there is differ region dvd's...no player will play multi unless u buy it that way....best bet is to convert your wrong region dvd's to non region
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
SOURCE: Want to dezone a samsung 1080p9 region 1 bought in
Hello Guillaume_0b
I would really need the model number from you to try and give you the correct info you are looking for.
Here is a web site that I normally use. GIve it a go
www.dvd365.net
This may have the code you are looking for if not try a couple on the samsung page they may sort you out.
Cheers
Little Dish Fitter
SOURCE: i need the multi region code for a Samsung DVD
Sorry, there isn't one. Your model is not hackable.
The usual Samsung hacks involve using the remote to enter the correct numbers but your model has no number keypad on the remote. Substituting a universal remote also does not work and I've been informed by Samsung that the region coding on this model is hardware encoded just like on many Sony and Panasonic models so you cannot even override the coding using a service centre remote control (I've tried). I discovered this when a friend purchased a large quantity of clearance overstock region 6 DVD H1080's and asked me to convert them for resale in the UK (region 2).
To hack your model requires internal hardware replacement and this is not economically viable.
