You shuld go to your provaider and change new sim card with your number then you can make new code . no other way for that the code its block into the network wen you change the sim you will have new sim serial then the network will accept your new baring code.
To get call barring password you need to contact your service provider.They will give you the call barring password.
While you get the call barring password, service provider will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the password.
Thank You
Default call barring password is 1234..To change the password go to settings then call barring. Select options then edit password. Enter current password then new password two times to confirm. Make sure to remember the password. To activate call barring dial *33*1234# if your password is 1234, then press send/call. To deactivate dial #33*1234# then press send/call.
"The barring password is required when using the Call barring service. See Security settings, 48. It has 4 digits. If the codes or passwords are not supplied with the SIM card, contact your local service provider'.
To bar all incoming calls To start, enter *35* password # To stop, enter #35* password # To bar all outgoing calls To start, enter *33* password # To stop, enter #33* password # To bar all outgoing ISD calls To start, enter *331 password # To stop, enter #331 password #
call barring password is the same password u use to open yr phone e.g if u start the phone it will ask u for a password , that password can be used for call barring unlock
