My type pics etc looked squished horizontally in wide mode but leave a black border in fit mode (though then the ratio looks correct). My computer only has 4 resolution settings, so I cannot set the correct resolution. Is there any fix, or do I have too much screen for my older computer?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Make sure that your software, that you view your pictures with, falls into the 'box format' of 640x480, 1024x768, 1280x1024, etc. Background pictures are typically streched to fit the wider screens. You can change that by right clicking on your desktop.. in XP it is the 2nd tab, on the right side, you can choose stretch or ? Some will give you black bars but no skewing. Then you can adjust your monitor's resolution downward to enlarge your pictures, or leave it at a higher resolution if you don't mind the borders.
-DellTech1
It sounds like your input signal is in 4:3 and the projector is in 16:9.
You need to adjust the "Resize" mode.
On your remote, press the "Resize" button (bottom-right of the remote, looks like a screen with two arrows pointing left and right [< >]) until it is in "Normal" mode. If that does not work, try setting it to "Border".
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
is it posible the menu settings have been changed, go into menu select picture check to see what mode it is on ie; 4.3 16.9 etc, set to wide screen 16.9
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
• 16:9 : Sets the picture to 16:9 wide mode.
• Zoom1 : Magnifies the size of the picture on the screen.
• Zoom2 : Expands the Zoom1 format picture.
• Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
• 4:3 : Sets the picture to 4:3 normal mode.
• Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
