To switch the radix mark between the US and European formats, turn the calculator off. Press and hold the decimal point key, then press and release the ON key, then finally release the decimal point key.
To switch the radix point between the US and European modes, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
Decimal Point and Separator Symbols You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator. • To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below. Display the selection screen. (Disp) 1. Press the number key ( 1 or 2) that corresponds to the setting you want to use. 1(Dot): Period decimal point, comma separator 2(Comma): Comma decimal point, period separator
P12c display from Comma to Point
This document describes how to change the display of the decimal
point on the HP 12C (HP12C) Calculator from a comma (commas) back to a
decimal point. Instructions
Turn off the calculator.
Hold down the decimal point.
Continue to hold the decimal point key, while turning
on the calculator.
The comma should change back to a decimal point.
Explanation
The comma is the European equivalent of the decimal point.
This procedure is also applicable to HP12CP (Hewlett-Packard 12c
Platinum) and HP12CPA (Hewlett-Packard 12c Platinum 25th Anniversary
Edition).
From HP12c FAQ:
This document describes how to change the display of the decimal point on the HP 12C Calculator from a comma back to a decimal point.
Instructions
Continue to hold the decimal point key, while turning on the calculator.
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
