Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
Posted on Apr 03, 2009
Xbox 360 Does not recongize my wireless adapter
When I plug in my wireless adapter to my 360 and go to my network setting it does not show my wireless adapter, my adapter has a red light but my 360 just does not recognize it.
Any Suggestion?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2296
Points
9
My adapter light is a solid red. When I plug in an ethernet cord, that'll connect.. but when I take the ethernet cable out, the 360 always reports Disconnected under Network Adapter even though the wireless adapter is plugged in.
tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
tip
How to set up the Xbox 360 Wireless N Networking Adapter
Overview
If you connected to Xbox LIVE after October 28, 2009, a software update was installed on your Xbox 360 console to support the Xbox 360 Wireless N Networking Adapter. If the update was installed on your console, all you need to do is to configure the wireless settings. To learn how to do this, please see the following article:
908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
If you have not connected to Xbox LIVE since October 28, 2009, you will need to use the installation disc included with your Xbox 360 Wireless N Networking Adaptor to install software on your Xbox 360 console.
To install the software for a Wireless N Networking Adapter
1. If an Xbox 360 Wireless N Networking Adapter is plugged in to your console, unplug it.
2. Insert the installation disc included with the Xbox 360 Wireless N Networking Adaptor into your Xbox 360 console.
3. Turn off the console.
4. Turn the console back on.
The software update should start automatically. If the update does not start automatically, the software might already be installed.
Note If you receive a mixed media error message, please see the section titled "Mixed media error message" below.
5. When you are prompted to install the software, select Yes, update now.
6. If a network cable is plugged in to the back of your console, unplug it.
7. Once the installation is complete, plug the Xbox 360 Wireless N Networking Adaptor into the USB port on the back of your console.
For information about attaching and configuring your wireless adapter, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
8. Remove the installation disc from the disc drive.
9. Turn off your console, and then turn it on again.
If you receive a mixed media error message, auto-play might be turned off. Here’s how to turn it on:
1. On your console, go to My Xbox, and then select System Settings.
2. Select Console Settings.
3. Select Auto-Play.
4. Select Enable.5. Repeat the steps for installing the wireless adapter (above).
Next step:
For information about how to configure the wireless settings on your console, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 consoleDo not try to repair the wireless networking adapter.
Do not take your Xbox 360 console or accessories to a retailer for repair or service unless an Xbox support agent instructs you to do this.
Do not try to disassemble, service, or modify the Xbox 360 console, the power supply, or any accessories. If you do this, you might put yourself at risk of serious injury or death from electric shock or fire. For your own safety, such actions will void your warranty.
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
XBOX 360 WIRELESS ADAPTER
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again
2answers
What are the steps to hooking up your xbox 360 wireless network adapter
Hello
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
1helpful
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Xbox 360 wireless
There should have been an instruction manual that came with your wireless adapter. But anyways, you may be connected to a password protected router and need to put in the password via the dashboard. I'm pretty sure you would goto network settings and then select the network you'd want to connect to.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
