Panasonic KX-TG1100 Cordless Phone Logo
A
Anonymous Posted on Aug 04, 2013
How do you delete block numbers from the handset? I put in the blocks and now it says memory full- I need to delete a few of them
1 Related Answer
Anonymous
  • Posted on Nov 09, 2010
SOURCE: how do i delete phone numbers in my blocked number
Go to Menu > Initial Setting > Call Block Then you can scroll the list and delete numbers from the list.
2answers
How to clear all blocked calls from my KX-TG7871
To clear all blocked calls from your Panasonic KX-TG7871 phone, follow these steps:
  1. Press the "Menu" button on the handset.
  2. Use the up and down arrows to scroll to "Settings" and press "Select".
  3. Scroll to "Call Block" and press "Select".
  4. Scroll to "Block List" and press "Select".
  5. Use the up and down arrows to highlight the number you want to unblock.
  6. Press the "Erase" button, then press "Yes" to confirm.
  7. Repeat steps 5 and 6 for all numbers you want to unblock.
  8. When you are finished, press the "Off" button to exit the menu.
Note that if you want to clear all blocked calls, you will need to go through the list and erase each number individually. There is no option to clear the entire block list at once.
How to empty the blocked call memory on a Panasonic KX-TGD664M
When the phone system is in standby (no calls in or out), press Call Block (the middle button in the bottom row of keys) on a handset. Press the Up/Down arrows to choose Block a single number or Block a range of numbers. Press the soft key for select. Press Menu (right soft key) and use the arrow keys to highlight Erase All. Press Select. Then confirm the deletions twice by highlighting Yes and pressing Select each time. You will need to repeat the steps to delete the calls in each of the Call Block databases. Press Off to exit the menu.
Deleting numbers from the Call Block database is shown in the manual for the KX-TGD664 on page 29. Panasonic.ca has the manual on the phone support page: https://eng-ca.faq.panasonic.com/app/answers/detail/a_id/58889 . The current link to the manual is https://help.panasonic.ca/PCS/OperatingInstructions/KXTGD66_Series_OIManual.pdf .
I hope this helps.
We have used up all our blockable numbers on our land lined. calls keep coming in. How can we erase space on our phone to make room for new blockable calls? The phone is a Panasonic KX0-TGE430/
Do you mean the KX-TGE430? This is the base for the KX-TGE432, KX-TGE433, and KX-TG3634. To delete numbers from the Call Block, press the Call Block key (bottom right of the handset). Choose the single number or range of number option using the arrow keys. Press Select (a soft key - see the display). Use the arrow keys to highlight a number or block of numbers in the list. Press the soft key for Delete. Highlight Yes and press the soft key for Select. Press Off when done. Alternatively, after entering either the single number or range of number call block section, press Menu. Then choose Erase All. Highlight Yes and press Select.
The manual for the KX-TGE432 is available at ManualsLib: https://www.manualslib.com/manual/1143858/Panasonic-Kx-Tge432.html . See page 24 for the information on deleting numbers from the Call Block memory. https://www.manualslib.com/manual/1143858/Panasonic-Kx-Tge432.html?page=24#manual .
I hope this helps.
How do I erase call block numbers. Phone says call block full. KX-TGF370
USING THE HANDSET menu
1 CALL BLOCK
2 SELECT "Block a single number" or "Block range of numbers"
3 Select the desired entry.
A After viewing, press OFF to exit.
B To edit a number: EDIT a Edit the number. SAVE OFF
OR.....
C To erase a number: ERASE : "Yes" SELECT a MOFFN
How to unblock a Vtech cordless phone with blocked caller the model number is:CS6919
With the handset in standby mode, press Menu (on the right below the LCD screen). Use the Up/Down arrows to navigate to Call Block. Press Select (the same as Menu). Navigate with the Up/Down arrows to highlight the line Block List and press Select again. Navigate to the line Review with the Up/Down arrows and press Select. Use the Up/Down arrows to navigate to the blocked number that you wish to delete. Press the Mute/Delete button (the center button below 0). You should hear a confirmation tone and either the next number in the block list or list empty should appear on the LCD screen. (You can't delete the entire list at once.)
The procedure to delete a blocked item in the Call Block list is given on page 21 of the full manual. The manual is available from VTech on the product page: https://www.vtechphones.com/store/pd/3370/CS6919-Cordless-Phone-with-Caller-ID-Call-Waiting . The direct link to the manual is https://cdn-media.vtechphones.com/products/CS/CS6919/CS6919-X_WEBCIB_V4_20160224.pdf .
I hope this helps.
1helpful
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
How to clear a memory full in the block feature on the KX-TGF370?
if you haven't deleted all your old voicemail messages. press * 5
if your directory is full, you will need to delete one or two saved numbers in order to add another.
1helpful
How can I reset Call block memory full
Remove the power cell, let it sit a few minutes and reinstall the battery. That should clear the memory. If not; contact the manufacture for assistance.,
45helpful
4answers
How to clear a memory full in the block feature on the KX-TG4031?
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
41helpful
2answers
I blocked calls on my panasonic KX-TGA652 and now want to unblock or delete them because it is full and I don't see how to do it
Go to Menu-Initial settings click Select button. scroll to Call Block hit Select ,then Scroll for numbers you want to Unblock..
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
