Upon startup, I hear several beeps, a pause, and then several beeps again. This pattern continues indefinately. Nothing ever appears on the monitor.
I don't know what to do!
Thanks for you help.
This is a classic bad ram beep code. Take one of the sticks out and reboot. Then do same with next..if both are bad then beep will continue. Just buy some more RAM and install it will be fine.
Please rate this solution.
You need to check the memory .. turn off the pc .. unplug it .. open the case remove the memory module(s) and re-install .. plug it back in .. then try again
Turn on your PC and listen for a beep. Your computer runs a diagnostic upon startup called "post." Post checks for the basic requirements for your system. This includes RAM, processor and video functions. If those three basic elements are working properly, you will hear one beep from your computer's speaker and you can be assured your processor still works.
If you hear multiple beeps, count the number of beeps you hear as this will help you determine if your processor is functioning properly. If you are running Phoenix BIOS, make sure you count and write down the beep sequence.
Consult your motherboard's BIOS instruction manual; there will be a section on the "post" startup. Five beeps means a processor error for most standard AMI BIOS systems. The number of beeps you here will tell you the problem your computer is experiencing that is preventing it from booting up. Once you know how many beeps to look for, you can safely determine if your CPU is still functioning properly.
