Question about Canon PowerShot A75 Digital Camera
How to fix a Canon Powershot 300 camera lens error.
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: lens error message Canon Powershot A550
Canon A550 and A560 have the same body and most of the internal parts, including lens assembly are the same. Canon won't sell individual parts within the lens assembly. There could be two possiblities. One is (unlikely) that the lens assembly components have been knocked off from their position. The other is that because of a knock, or dropping the camera, the gears in the gearbox of the lens assembly are broken. These gears are the same as the ones in A530/A540, and are available from ebay for $12.50 including shipping. Checkout my site for how to open up the camera and the lens assembly to replace these:
http://pkrobot.freehostia.com/MiscElectronics2.htm
For A550 and A560, if you take it to the professional repair shop, it might not be cost effective, since it might cost around $90. Canon does not sell gears, so they might have to replace the entire lens assembly. The new camera is available these days for around $140.
Posted on Feb 17, 2008
t00nz
CameraR
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 30, 2009
  • 102366 Answers
SOURCE: lens error, restart camera for canon power shot SX120 IS
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Posted on Feb 14, 2010
Ty Price
  • 11967 Answers
SOURCE: my canon powershot a1100is says lens error restart
That just means to turn it off and then on again. Try these for "lens error"... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Posted on May 11, 2010
Camera says lens error, restart camera...
Hi, On Canon camera's that error is typically seen when the camera's been dropped and the lens is now out of place. For the A490 specifically that's something that can't be fixed as it's such an inexpensive camera and fixing that problem, if it can even be fixed, costs upwards of $300.
Aug 29, 2011 | Canon PowerShot A490 Digital Camera
Canon PowerShot A720 IS - "Lens error, restart camera".
Feb 07, 2010 | Canon PowerShot A720 IS Digital Camera
Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon Powershot S2 IS Disassemly guide?
Here are some things that you can do to try to correct it without disassembly. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 22, 2009 | Canon PowerShot S2 IS Digital Camera
Powershot A560
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 15, 2008 | Canon PowerShot A560 Digital Camera
Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 09, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Nov 03, 2007 | Canon PowerShot SD600 Digital Camera
Your Camera is full of sand and you can try blowing it out and banging it out. But I'd say it's time for a new camera. Regards Thestreeker
Sep 18, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
