Maytag Neptune FAV6800AW Top Loading Washer Making loud noise now when washing.
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
also check if something stuck up in spin assembly
thanks and please do not
forget to accept the solution
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A help for solving the OD error code.
Fixed
I appreciate the help. With the Service manual I removed the tumblers and found an assortment of change so I removed it and cleaned all the exposed areas of the drum. So far working like new. Again thanks for the tips
If it’s not too much to ask would you mind sharing what the fix action was. Thank you.
To remove the front panel of the machine ypo will need a 5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the Service Manual
Hello gwatson01,
