Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: i have the bosch
how is heating element ? Wasit on with no water running thru it. Does it have a reset?
SOURCE: I have a powerstar tankless hot water heater Ae9.5
Before calling service technician, copy following link for some troubleshooting resources.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
SOURCE: PowerStar. Model 45-557701
I have had no hot water and have fixed it by removing the inlet screen and cleaning it, also make sure the water flow thingy is spinning in the clear inlet side of the heater. If your on a well or have questionable water algae can affect the flow indacater very gently tap the clear plastic while you have the hot water flowing only if it not spinning . It fixed mine. I ended up dumping bleach in my well to fix mine. Hope this helps someone, nothing like getting ready to go to work and having no hot water!
