SOURCE: ryobi weed eater will only run if i hold the choke down
Mine won't spin up till it is good and warm. Check the end of the fuel line in the gas tank to see if it is clogged or dirty or slimey. Make sure the end has not fallen off.
SOURCE: remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
SOURCE: My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
i had the same problem and it was drawing air at the base of the head so i thightened up the bolts and run sweet colin
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
SOURCE: how do i restring my ryobi weed eater
Check the video at the link I am providing and see if it helps you out. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
