MSI K9MM-V Motherboard Logo
Anonymous Posted on Aug 03, 2013
I put a disk not usb what is the menu to do installation describe the steps to install xp
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • MSI Master 2,226 Answers
  • Posted on May 19, 2014
James Miller
MSI Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447457
Points
2985
Disk in to dvd then do the steps it show
1helpful
2answers
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 • Computers & Internet
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
How can i format my laptop
Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
Step 2
Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
Step 3
Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
Step 4
Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
Step 5
Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
Step 6
Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
2answers
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
1helpful
3answers
Have windows vista and wanting to install xp
Installing Windows XP on a SATA Drive
Author: DJ Oslo
Date: August 18, 2007
Description:
This tutorial will describe step by step how to install XP on a laptop with a SATA hard
drive in order to downgrade the operating system from Vista to Windows XP SP2. The
laptop model that this tutorial is based on is listed below:
Model: Toshiba X205-S9349
In order to install XP, you will need the following software:
Windows XP SP Installation CD
nLite (http://www.softpedia.com/get/System/OS-Enhancements/nLite.shtml)
Introduction:
If you want to downgrade to XP from Vista you may run into a problem during the boot
stage of XP Installation. The problem I encountered was a message that read:
“Setup did not find any hard disk drives installed on your computer”
The problem is that XP does not provide the necessary drivers for the SATA controllers
and as a result it won't detect the SATA hard drive. You could use an external floppy
disk drive but that might not guarantee success.
What has been suggested is that you perform a procedure called "Slipstreaming".
Slipstreaming is the procedure where you create a new build of the XP installation files
and "merge" the drivers you need for the SATA controllers. You would then use this
new build to install XP onto your system.
Note: These procedures were performed on my Toshiba P105 laptop, which is my current
working laptop.
Step 1.
Create a directory under My
Documents where you will
copy the contents of your
XP installation CD.
Step 2.
Download the SATA driver that you will need in order to “Slipstream” into your XP
installation.
The following link is to the SATA drivers that will work with the Toshiba X205-S9349.
http://209.167.114.38/support/Download/files_Downloads/pspb7c/Intel-Matrix-Storage-Manager-V1.0.0.1082.zip
Step 3.
When you download the .zip file,
unpack the contents in a new
directory under My Documents.
Step 4.
Open nLite and locate the
directory where you copied
the XP installation files to.
Click on the Next button.
Step 5.
You will get information on the
Product. Click on the next button.
Step 6.
Step 7.
In the Task Selection, you will click on
the button called Drivers and Bootable
ISO. After you click on each button the
red dot will turn green. What this means
is that you will “integrate” drivers into
the installation and then create a bootable
ISO file.
Step 8.
Step 9.
Click on the Insert – Multiple driver
folder option to select the drivers that
you will integrate.
Locate the folder where you
unzipped the SATA drivers.
Highlight the folder and click OK.
Step 10.
The following drivers will be listed.
Note: you must select the correct driver to
integrate or else you may experience errors
during the installation phase of XP.
Select the first driver.
Click on the OK button.
Step 11.
Select all the items to
integrate. Click on the OK
button.
Step 12.
Step 13.
Highlight all the drivers and click on
the Next button.
Select Yes to start the process.
Step 14.
nLite will now apply the changes
to the installation files.
Step 15.
When complete, it will display how
much the installation grew. Click on
the Next button.
Step 16.
In the Bootable ISO section, click on
Make ISO.
Step 17.
Step 18.
You will be prompted to save
the ISO file. Select where you
want to save it and click on the
Save button.
nLite begins the process of
creating the .ISO file that can
then be burned to CD and used
as the installation file for
Windows XP.
Step 19.
You should get a message
that the ISO file has been
created successfully. Click
on the Next button.
Step 20.
Step 21.
Open your CD burning software. In this example I will use Nero Burning ROM.
Customization is finished.
Click on the Finish button.
In the menu bar, I select Recorder – Burn
Image…
Step 22.
Step 23.
I locate the ISO file that I created in
nLite. Highlight the file and click on
the Open button.
Click on the Burn button. This will now
burn the ISO to CD and thus create your
new XP installation that will install the
SATA drivers during the boot stage of XP
installation. this is 100% working thank very much
6helpful
6answers
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
