Maytag M3DH30B2A Dehumidifier Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Machine runs fine with dry air exiting but the tank is always empty (bone dry). It just stop collecting moisture, and there is no way the basement is moisture free.
Anonymous
Level 2:
  • Expert 67 Answers
  • Posted on Apr 02, 2009
Anonymous
Expert
Level 2:
Answers
67
Questions
0
Helped
42821
Points
212
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
The dehumidifier 20L that I have does not produce any water when on. The tank is always empty and the humidity hardly changes even though a separate humidity meter shows say 68%.
It sounds like it needs servicing and recharging with refrigerant gas. It works by running the moist air over refrigerated elements where the moisture condenses and drips into the tank. Make sure you are on the right setting, most have 'blow air, remove moisture, and A/C'..
tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 • Dehumidifiers
I have an Idylis dehumidifer with pump model 0526051 does it need a hose in the water tank to pick up the water in the tank?
Normally dehumidifiers collect the water that they have pulled from the air in the tank. Therfore no hose is required. You just have to empty the tank when full. Most models have a float switch which shuts off the machine when the tank is full. Hoses to get rid of water are normally only fitted on industrial machines.
The dehumidifier is running constantly but no water is being collected
Sounds like you're in a wintery environment. Most people operate a humidifier in those locations because the air is too dry. If that is your situation, I suggest you turn the dehumidifier off until Summer and save electricity. If will pull moisture out of the air in the summer.
1helpful
I have a Kenmore 48 pt. dehumidifier Model#: 5548 (106-855481). It sounds as if the compressor cycles on fine; however, the water pan remains bone dry without a drop of water or moisture in the pan. The...
Do the coils get cold and the unit blow cold air? If not, the compressor is not really working.
Please rate 4 stars if this is helpful. Thanks and good luck!
It is not taking moisture out of the air. The tank is bone dry, yet the controls indicate it is in moisture removal mode, the fan is running and the temp gauge shows 60% rh. Also we suspect it is drawing...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Our AD25THO. Runs fine but has recently stopped collecting water. It's dry as a bone and our basement is very damp. What's wrong with it?
heatman101
Our humidifer runs but does not collect water.
Againg, if theres no moister in the air it wont remove water. if you feel the location for exmaple a basment feels cool when entering , then mosuet exist. dehumidifer will make any location warm when removing the coolnest in the air. within summer hot months it will collect more water than in the winter months. if it does feel cool and machine dont remove the water. call a repair person.
3helpful
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
6helpful
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
