The other practical alternative of Drill Woodworking is for drilling holes into wood, which is on occasion additionally stated a pedestal drill, pillar drill, or bench drill.
more details Best Drill Press 2018
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
SOURCE: How do you correct excessive drill wobble on a
First you have to determine if it is the spindle or the chuck assembly. I would go to ereplacementparts.com and look at a breakdown for this tool so you know what the parts look like and then go from there. I couldn't find the schematic on the Ryobi site.
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
SOURCE: can't remove the chuck on my mastercraft drill press.
I just bought the exact drill press #55-5917-0 and I had to assemble it . The shaft that the chuck is on is tapered and the chuck is tapered on the inside , so you will have to put a wedge on each side of it and lightly tap on the wedges until the chuck drops out.
