I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
I just had this same problem when I unplugged my rs2555sl to install a surge protector. The "Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds" diagnostic procedure was the solution. BTW: I bought my rs2555sl in 2003, and except for the ice maker, I haven't had any problems with it (knock on wood). I've had the ice maker service under an Best Buy extended warranty, but I understand that ice makers in side-by-side refrigerators are usually the flakiest parts.
Same issue. The front panel lights were off with only one blinking light working. This was after a heavy storm that caused multiple power outages. Holding down "power freeze" and "power cool" for approximately 10 seconds displayed code "3) after which the fridge started working OK.
Similar to the other comment I have replaced the ice maker twice already and it is still not working properly.
I have a samsung refrigertor RM25KGRS and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was blue light blinking on the refrigerator temp display.
Hold down the "freeze" and "Fridge" buttons at the same time for at least 8 seconds and then the panel should function again.
Worked for me
Thanks forum guys, and thanks
Solution #1 worked for me!! Thanks forum guys, and thanks NHJay, you guys are awesome!
Call service
MY FRIDGE WAS DISPLAYING 86 88 ON THE PANEL I PRESSED ENERGY SAVER AND LIGHTNING FOR 10 SECONDS TO RESET IT RESET THE PANEL AND IT START WORKING NORMAL
Mine is model RB29FERNDSS what ive did is press the fridge and freezer button for about 10 secs it actually worked but after waitung for a couple of hours the ref doesnt seem to cool at all what should i do thanks
No solution, this did not work at all on mine. there is one blue line and it is the top of one of the numbers for the display. I have unplugged it, tried to reset it, nothing....Any Suggestions other than.....buy a GE
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
I don't have a solution, but a question...I just tried this 8 seconds solution, and I got a "3", Does this mean that I have to fix something? Or, just wait and see how the ref, reacts?
