Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
A
Anonymous Posted on Aug 02, 2013
DIPLOMAT SELECT 920 STUCK IN AUTOMATIC - Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
1helpful
Just moved and have diplomat built in single elec oven checked inside but cant find model or serial no. 2 knobs on left all symbols gone some push buttons middle and knob on right numbered 1 to 5
Hello -
Please double check for the model number. It will probably be on a small metal plaque on an edge of the oven door, along the outer edge of the oven opening, or in the oven interior. It could also be on the top of the oven and covered by cabinetry.
Undo the screws that hold the oven in and slide it out 6 inches. You may then find the metal plaque on the top of the oven. You may need the help of another person when you try to pull the oven out, so that the oven does not tilt forward and fall to the floor.
You MAY be able to identify your model of Diplomat oven from one of the images of Diplomat oven control panels here:
https://manuall.co.uk/diplomat-select-620-oven/
Page 6 (PDF document image 7). Note: Use the + icon to enlarge the image.
You may find the image of Diplomat oven knob markings here helpful:
https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/61498-diplomat-adp4890
Scroll down that page to the post dated 14-12-14 from pslewis333 to see the image.
Once you know which model of Diplomat oven you have, you may be able to find and purchase decals with the proper knob markings for your oven so that you can affix the decals around your oven knobs. Or, you could use heat resistant paint and a small, pointed paint brush to paint the markings on your oven. With either option, I suggest you seal the markings with a heat resistant clear sealant so that cleaning / scrubbing will not erase the markings.
Best wishes.
Jan 24, 2019 • Ovens
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 • Ovens
1helpful
I hava a diplomatic 920 double oven cooker and want to but another one just the same were can i get one from
Diplomat is produced by L.M. Electical and is sold through e-bay . I understand that its UK based manufacturer.
Telephone 01761 411111
Dyson Spares Washing Machine Door Seals items in ELECTRICAL store on eBay
Oct 11, 2015 • Ovens
1helpful
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 • Ovens
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 • Ovens
4answers
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 • Ovens
2helpful
2answers
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to [email protected] and I will reply with a copy in .pdf file format.
Dec 24, 2007 • Ovens
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
