SOURCE: Acer AT2001 cannot use as monitor
I currently own an Acer AT2001 21 inch Television/Monitor. The refresh rate on your computer should be set to 60Hertz. You can change this setting by right clicking the desktop, click properties, click settings, click advanced, click adapter, click list all modes, click 800by600 at 60Hertz. The screen resolution will not go above 800by600. Note; Initialize these settings with an old crt monitor and then plug in the Acer.
SOURCE: Problems with Acer AT2001 20 in.
you need to go to:- My computer/control panel/display
you should be then into the display settings panel. at the top of the panel, select settings. and you should set:- colour quality Highest 32 Bit ( or whatever the highest is )
Then Screen resolution ( bottom left ) should now be 800-600 to 1024x768 or similar.
Whichever is best for your monitor.
if you can,t acheive this. you need to re-install any drivers for your graphics card or onboard vga.
Thankyou for using Fixya.
Mike @ Compurepair.
