Is there any way to disable the automatic shutoff on drip coffee
Most drip coffee makers nowadays have an auto shutoff feature built in. Is there a way to defeat this feature so the heat pad stays hot allowing the remaining coffee to stay hot?
The K-Select™ brewer will automatically turn off after 2 hours of idle time. Theauto off feature can be disabled if you wish to keep the brewer on at all times.
1 Answer. To cancel the Auto Off feature: Press the MENU button twice to reach the "AUTO OFF" MENU programming mode. Press and release the blue Left Button under the blinking "H" to advance one hour at a time until "OFF" is displayed.Dec 18, 2017
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Description: Buy 'Pro Line Series CoffeeMaker' online from HomeClick. Pro Line Series CoffeeMaker - KPCM050 Please Choose Color Finish (Additional images Available), Available in Onyx Black & Nickel Pearl Product Features, Makes 12 Cups, Die Cast Metal Construction, Stainless Steel Heat Pump & Brew Basket, Digital Brew Timer & Clock, 24 Hour Programmable Timer, Front-Fill Reservoir, Automatic Shutoff, Audible Alert Tones, Time Since Brewing Display, Quiet Finish Brewing Display, Ion-Exchange Water Filter, 2 Year Hassle Free Replacement Warranty
Product Description
Program your Krups AromaControl Therm Time Coffee Maker the night before and wake up to the wonderful smell of your favorite coffee. With the Flavor Release Technology, this innovative machine allows hot water to saturate coffee grounds longer than traditional coffee makers, providing a more full-bodied, richly-flavored coffee without any bitterness. Hermetically sealed, double-wall, stainless steel insulated carafe with drip-free pour spout keeps your coffee hot for hours. Automatic shut off after 2 hours is a great safety feature.
I'd love to find a solution. I just got a black & Decker spacemaker coffee maker and although the features and instruction manual say nothing about an auto shut off, it is shutting off in just 2 hrs.
The only answer posted to the hopefull inquiries about disabling the auto shut off is rediculous. We all know how to turn the coffee maker off sooner than it turning off by itself for crying out loud !!!
