1.Install your wireless network adapter
in Windows XP with SP2. This process includes installing the proper
drivers for your wireless network adapter so it appears as a wireless
connection in Network Connections.
2.When the computer is within range of the wireless AP operating in your
home or small business, Windows XP should detect it and prompt you with
a Wireless networks detected message in the notification area of your
taskbar.
3. Click the notification message. If you are not notified, right-click
the wireless network adapter in Network Connections and click View
Available Wireless Networks. In either case, you should see a dialog box
with the name of the wireless connection.
4 Double-click your wireless network name. Windows XP will attempt to connect to your wireless network.
5.Because Windows XP has not been configured with the WEP encryption key
for your wireless network, the connection attempt will fail and Windows
XP will prompt you with a Wireless Network Connection dialog box. Type
the WEP key in Network key and Confirm network key, and then click
Connect.
6.If the status message for your wireless network in the Wireless
Network Connection dialog box is Connected, you are done. If the status
message for your wireless network in the Wireless Network Connection
dialog box is Authentication did not succeed, click Change the order of
preferred networks in the list of Related tasks. From the Wireless
Networks tab of properties of your wireless network adapter, click the
name of your wireless network in Preferred networks, and then click
Properties.
7.In Network Authentication, click Open. In Data encryption, click WEP.
In Network key and Confirm network key, type the WEP encryption key as
configured on the wireless AP.
8.In Key index, select the key index corresponding to the encryption key memory position as configured on the wireless AP.
9.Click OK to save changes to the wireless network.
10.
Click OK to save changes to the wireless network adapter.
Source(s):
http://www.microsoft.com/technet/network...or
for broad band connection
To create a broadband connection using PPPoE, use the following procedure:
Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
Under Network Tasks, click Create a new connection, and then click Next.
Click Connect to the Internet, and then click Next.
Click Setup my connection manually, and then click Next.
Click Connect using a broadband connection that requires a user name and password.
In the Connection Name dialog box, type the name of the ISP. This becomes the name of the connection. Click Next.
In the Internet Account Information
dialog box, type the user name and password. Additional checkboxes allow
you to specify whether this connection and its user name and password
is available to all users (selected by default), whether this connection
is your default Internet connection (selected by default), and whether
to enable the Internet Connection Firewall on the connection (enabled by
default). Make the appropriate selections, and then click Next.
In the Completing the Connection Wizard dialog box, review the settings. If you need to modify any of them, click Back as many times as necessary. If all the settings are correct, click Finish.
In the Connect dialog box, click Connect to attempt the connection
- or you follow the another link
http://technet.microsoft.com/en-us/library/bb456997.aspxFOR WIFI
First, you should get
wireless internet on your computer (thorugh a router) or get a Wi-fi USB (they're discontinued, so look hard if you want one)
Now you can either watch this video, follow this link or simply have a look at my steps:
http://www.ehow.com/how_2059775_connect-...
http://www.youtube.com/watch?v=e-jJZUtf0...
1. Click the
Wii options button in the bottom left corner on your starting screen
2. Choose wii settings
3. Scroll to page 2 using the arrow on the right
4.Click internet
5.Choose
connection settings
6. Click on connection 1, 2 or 3
7. Choose wireless connection
8. Click "search for an access points"
9. Click OK
10. Choose the from the connections your Wii has found (Look for your
connection. You might have to provide some sort of password)
If all goes well, you'll have to click OK a couple more times, wait for
it to test the connection, then the Wii will reset itself and then
you'll have internet!
