Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
