SOURCE: av mode no remote
Just off the top of my head I think the code was 720... I havent installed DishNetwork dishes in a while though.. I will double check to get you the right code.
SOURCE: I just got a used
I hope that you have gotten this resolved, but if not, here are some simple steps to try! If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73. I hope this information helps!
Becki Barned
DISH Network Customer Service
SOURCE: dish tv remote code
Hi L. Pruett, my name is Mike Houston of DISH Network and withthe Durabrand TV there are a couple of codes we do have for that TV. The threedigit codes will be 220 and 233 and what you will want to do is hold down the clearTV button until all the mode buttons light up. Press one of the three digitcodes I have sent press the # button and then press the Red TV button on theremote, the TV should have turned off and if not after trying the two 3 digitcodes I will send you a link for a Power Scan; http://www.dishnetwork.com/SupportSection/power-scan-instructions- Mike H.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
