I have a Tassimo beverage maker. I have tried several different times. Only about 1/3 to 1/2 of the contents empty from the creamer T-discs each time I make a cappuccino or latte coffee. I've tried cleaning the bar code reader, shaking the discs vigorously and cleaning the machine up, but it still doesn't empty the contents. How can I get it back to working flawlessly as it did for the first year of opperation
Same problem, used descaler as instructed and all was solved and brewing back to normal:)
Please can someone help, the pods are just not emptying.
Having the same problem,I've cleaned mine with the disc I tent to just put the coffee disc in again that helps a bit
Just change the order of T-Discs. Milk first and espresso last, which will solve the issue. I think the problem is about the lack of hot water during making a cup of drink.
Looks like there are a great deal of people having the same issue....maybe its the tdiscs themselves.....i did notice a month ago they were all off the shelves.
Do you have it set to MANUAL????? if it's on manual, it only puts so much water into the disc, therefore allowing you to customize the flavour and amount. If you have it set on manual and not AUTOMATIC, this could be the problem!? HTH!!!!
I have the same problem. Someone told me to get descaling stuff and descale it - will try today. But I've cleaned everything else. Am tired of burning my fingers squeezing out the rest of the fluid!
Hi Noel,
Same problem here. I wonder if you ever solved yours? Please share if so.
BTW I think what is left in the disc is more hot water plus milk rather than just milk, not that this matters too much.
We miss the foam on our cappuccino! And like noel5, all was fine for over a year.
