SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad F6 means no ac signal and will need to replace the oven control.
SOURCE: Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1
1.
Watchdog on board
To determine
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
Replace
F5
Hardware and
Replace clock
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
SOURCE: Magic chef gas range repeated F1 and F3 error
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Here
is a tip that I wrote that will help figure out why the burner spark
keeps on clicking...
Gas Range Repair Burners
Keep on Clicking
heatman101
