We have a Whirlpool electric double oven model # RBD305PD. Out of the blue, it started to beep and there is no digital display on the control panel -- just an error code F2 E6. Sometimes it just goes black, and sometimes it comes back to life with beeping and the same error message!
I tried the breakers over night & still didn't work.
Any smart tech experts out there who can help me fix this?? Thanks!
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad
(also called touch pad or membrane switch). Some models incorporate keypad
in to control board as one unit. In this case, replace control board (also
called ERC or clock).
I don't know how to access the control panel connections!
