Cyberhome DVD Recorder - DVR1600 Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CONNECTING RECORDER TO TV AND DVD PLAYER
I WANT TO CONNECT MY SURROUND SOUND DVD PLAYER AND MY TV TO RECORDER TO RECORD MOVIES. I CANT FIND MANUAL. WHAT WIRES CONNECT WHERE? CAN YOU HELP?
Eric Morris
Level 2:
  • Expert 75 Answers
  • Posted on Apr 02, 2009
Eric Morris
Expert
Level 2:
Answers
75
Questions
Helped
17422
Points
136
I have the manual for this ;asking around 7.50 with free shipping, call if interested 2095683327.willing to drop price a little.
1helpful
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
2helpful
2answers
How to connect dvd recorder to tv????help
if youre going to be recording programs from the TV , it cant be , normally TV s have A/V
inputs and NOT outputs , the only way is to connect it thru a VCR A/V outputs , hope it helps , AJ
2answers
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
Don't have manual to connect my Panasonic DVD Recorder DMR-ES15.
http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.PDF
Want to burn some movies off my dvr
http://www.usersmanualguide.com/
see if theres a manual here
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
I cant get go video model #r6740 to be able to be connected to my cable box and still work help please
connect the yellow, white, and red cables from your cable box (output) to the (input 1) connector on the dvd recorder. Then connect the yellow, white, and red cables from your dvd recorder (output) to a (input) on your tv (make a note as to which input on the tv you use). then turn on your tv (set your tv by pressing input, line, or channel down from channel 2 until you see the input you connected your dvd recorder to). then power your dvd recorder on (you should see it on your tv screen), then change the input on your dvd recorder to input 1 (or which ever one you connected your cable box to). Then power on your cable box (now you should see your cable programming on your tv, passing through your dvd recorder). Now you should be all set to watch, and record what ever you want, (however most dvd recorders will not record copyrighted materal, their is a signal transmited ny the owner of the movie, or other content.)
Connections
I reccommend live service with me, but I can definitely help. Please mark this as solved and we will arrange a time to work setup out. The question should be marked as solved because the one ANSWERABLE question, about the DVD being recorded, is NO, unless it is a home movie. Not only is it illegal, but also VERY difficult to do. and your equip is not cabable. Thanks!
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
