The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Just clean the lazer iv done hundreds not with a disk use alcohol and qtip
Put the CD in e 05. Appear won't play it's a 528
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
