Have an ATT e-2126 answering machine with one handset. Worked ok till yesterday. Handset would not display previous caller id. Removed power from handset, plugged in battery and when the on button is pushed....display says connecting....., 4 secs later display says can't connect. Tried reset handset, reset base unit.... no chg. Battery is fully chg. Had unit 3 yrs. Any thoughts ?
SOURCE: ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
SOURCE: handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
SOURCE: I have a Panasonic KX-TCA132E
I have a panasonic KX-TCA132Ehandset, have managed unknowling turned the ringer off and now can't turn it on again, please help?
