Question about Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges
I have a Toto saftclose toilet seat but it doesnt close softly!!!
Is there a screw or nut to tighten so it will close softly again?
  • 687 Answers
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Posted on Apr 01, 2009
Watermark soft close seat lid not soft closing
check with your local plumber or the manufacturer .
Apr 10, 2018 | Lid Home
New toto promenade toilet tank lean forward and plumber put putty tape where it has contact with tile and bottom of toilet base.. Also alot of play in elongated toilet seat? please help
Tighten seat nuts, they are underneath, you will have pop open the tabs covering seat screw to hold it. If the toilet was level before tile saws installed call tilers back. The closet bolts may have come loose or closet flange is broken.
Feb 27, 2018 | Toto Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
The toilet seat is super loose and I am unable to tighten.
reach under and hold wing nut or nut while tightening screw if plastic screws are stripped any hardware or home store carry replacement screws
May 31, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
The close coupled toilet seat keeps coming loose. The two phillips screws keep turning and won't tighten. There seems no way to get to the captive nuts...???
I too could not figure out how to get to the nuts since the skirt completely encloses the base. Nor could my plumber until he called his plumbing supply store. They told him they use a type of rubber piece that can be pushed through the hole from the top and acts as a nut. I didn't see it replaced so I don't know the details but I do recall that when I tried to turn those phillips screws that there was a squishy feeling. I don't know how to tighten under those conditions. I recommend you call a plumbing supply store.
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges Logo
7,727 people viewed this question
Top Toto Home Experts
john h
Mike
choprboz5
Are you a Toto Home Expert? Answer questions, earn points and help others
