Goodman Model GMNT100-4
Furnace will run and continue to run for about 10 minutes, then the burners will shut down and the board will give a 4 blink code. After about a minute, it will ignite backup run for about another 10 minutes then power down for a minute, this cycle will continue until up to temp. While this happens the forced air blower continues to run will the ignitors are powered down, however the collector blower powers down with the ignitor. My question is, is this normal operation or is there a limit switch I have to replace.
Keep in mind all furnaces and circuit boards are not the same. Look on the back of the door to the blower compartment. You should find the list of diagnostic codes. Look up four blinks it should narrow down the problem. Although from the discription you gave it sounds lie the high limit control. When a high limit appears to be acting up it DOES NOT mean that the high limit needs replaced. The high limit just may be doing its job. This means that the furnace is overheating. Check your filters. Are all of your registers open? Is your blower set on the right speed? Is your blower going bad? Is the blower motor capacitor bad? Is your evaporator coil restricted? Just changing a high limit switch does not always solve the original problem!
Good luck....
