I have a dishwasher that sticks, it fills with water, drops the tablet & does a part wash but then, the program button starts flashing and will not do anything else,it heats the water ok but when I open the door, there is still water inside yet if I start it again, it emptys the water, then does the same thing again, have you got any ideas? Many Thanks John
Managed to get behind the facia. cleared the pipe by a combination of blowing and sucking (into a fixed on pipe)
Dishwasher is working fine now......thanks.
Turned out there was a block on the clear short pipe that goes to a pressure sensor situated to the left at the front behind the front facia under the door which the engineer cleared by blowing it!! The pipe connects to a little stub that sticks out of the blue plastic flow control thing on the lhs of the dishwasher. U can access this by removing the lhs cover but not really necessary...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mine does the same - its not the first time this has happened.Last time the engineer said it was a blocked filter, but i cant find any blockages... Someone must have an idea what causes it. I have cleaned all of pipes, filters etc out, removed the motor, & given it a once over? The motor seems to labour but not initially, it will pump out water if i fill it up manually, & it will start to work, perhaps its a pcb fault?
No, But when I got another one and was fitting it, I noticed that the waste pipe was clogged with lime scale at the bend where it goes through the wall, I think this might have had something to do with it as the pump might have had too much pleasure and then stopped, but it's only a guess. Hope this helps.
John
have the same problem.how do i get behind the front facia to access the pipe?
John, did u ever get your IZZI fixed? What wa sthe problem?
