SOURCE: HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
SOURCE: Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
SOURCE: Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
