My PC is very slow and is always displaying error messages, i do not have a anti virus will it help?
Use antivirus norton antivirus 2009 that will help you
Norton antivirus is probably the last thing you wanna install in a slow PC, it's a system hog!
I would go with a free version of AVG (go to www.AVG.com) to start, CCleaner (go to www.Piriform.com) is definitely something to use also.
Then Install and run Malware Bytes (go to www.MalwareBytes.org) , it might find things that AVG missed.
Check (with CCleaner) the startup programs (in Tools / Startup) and make sure that you do need the programs starting up. You can google the programs you're not sure about.
An other thing you could do is stop services running on your system for nothing, Windows has to please the masses, so it runs services that might be useless for you. (go to http://www.cas411.com/ShowArticle.aspx?ID=82 to find out how to do that)
Alex
If your PC hangs it can be due to some virus inside your computer. To fix this problem, you need to scan your system for viruses using some powerful antivirus program, limit your startup list, manage services and optimize your system.
In addition to it, repair Windows registry using some reliable cleaner such as Reginout Cleaner. Thanks
To speed up your PC a little you need to do a little mentenance work.
You should try to defrag the hard drive (eg. with Defraggler), clean your registry, clean your hard drive ( CCleaner).
You should also use a lite antivirus, because an antivirus can significantly slow down your PC.
Try using CCLeaner (ccleaner.com) which cleans most **** in yopur computer
Or use Uniblue Speedupmypc 2009 (uniblue.com - trial buy)
for speeding up processes and cleaning ****.
thanks
