SOURCE: how to port forward for microtorrent on belkin n1
Here is a good walk-through how to set up utorrent on your router.
Enjoy!
PS: Make sure that utorrent is not blocked by your Windows firewall!
If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: i forgot my password for my belkin n1 vision, how
Here is the manual in PDF. Hold the reset button for 20 seconds and wait for it to come back up. Then punch in the default login credentials from Belkin (the handbook will tell you how)
Good Luck!
Jesse
SOURCE: How do you extend the range of a Belkin N1 Vision
First connect your router to computer with ethenret cable.
Then you can access it with
http://192.168.15.1
If your rrouter is not access with this link then type in run "ipconfig /all"
then you get all adresese.
Gateway is ip adreese of yourt router so access it with those ip.
Type user name as "admin" and password as "blank or "admin" or "password"
then go to wi fi advanmced menu then change channel type 4,6 and 11
Try these 3 channel type 1 by 1 those give best result.
Set channel which give best result.
MAke sure when you set any settings in restart don't foget to save settings and restaret router .
Let me know if you need more assistanse.
Thanks.
SOURCE: Belkin N1 Vision
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
SOURCE: Belkin N1 Vision - Virtual Servers Add button doesn't run ok
Ascertain what incoming ports you need to open and the IP address of the device / computer that you wish to forward to and set the ports up manually.
· Enter a description for the service
· Enter the inbound port ranges from WAN
· Enter TCP/ UDP type
· Enter IP address that the service is to be forwarded
· Enter the private port range (keep these the same as the incoming ports unless you are running multiple services ie 2 web servers on port 80)
· Click enable check box and save entry
· Repeat as required.
