My 3-year-old Samsung RB1855SW fridge beeps every one minute (door ajar warning) even though the door and switch are positioned fine. The display for the fridge is wacky, but compressor is working. Cannot control fridge temperature, but freezer seems to work okay. I've unplugged and tried to reset. The beeping is driving us mad! Any suggestions?
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Our problem was fridge door alarm ,no cooling ,light out ,Freezer ok. Turned out to be the fridge side of the fridge/freezer door switch . Removing the double switch (it's a press fit) enables the fridge fan to work while waiting replacement. Replaced with new double switch now we have a light too.
Yes, I found a solution after ignoring a specialist's advice (house call $85 + tax and recommendations to replace parts that were operating just fine). The problem was the temperature relay switch (don't recall exact description) that cost $7.95 and was delivered via Sears in two days for an extra $6.
When the door opens, it shuts off the fan and cool air stops circulating. Since it's not working properly, the fridge senses that the door is open and will not turn on the fan when the door closes.
I couldn't believe the incompetence with the servicing company! No refund, of course, and no apology. The switch is easy to replace and snaps back in quickly.
Call this incompetent ******* and ask me for my money back:
Michael 'Mykhaylo' Shyban 778-892-7065.
Faulty fridge door switch, grab posts on switch and pull out and unplug until you get a new one. Beeping should stop.
I have the same exact same problem....did you find a solution?
Thanks,
Megan
Does anyone know how to safely remove the door switch. It doesn't pull easily.
Samsung Fridge Freezer with water & ice cuber beeps every 3 seconds and the vacation lock light flashes on and off in sync with the beeps.
If the vacation button is pushrd & held it stops.
This is a random experience and lasts for up to two days sometimes.
Seems to happen in rainy weather.
Anyone else had and cured this problem??
I am having the same problem....no consistency, it just randomly starts beeping and the temperature display for the refrigerator goes nuts....I have not been able to figure out how to stop it.
