Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other problem and no build up of ice anywhere. I tried changing the humidity settings - nothing happened. There is no water on the floor..... and freezer working fine. Door is not opened very much as I live alone. Any suggestions>
Anonymous
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Apr 01, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
93278
Points
784
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect I have the top mount refrigerator - 4years old. - new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
Sergeant:
  • Expert 531 Answers
Anonymous
Expert
Level 2:
Prodigy:
Sergeant:
Answers
531
Questions
0
Helped
196015
Points
890
The refrigerator door may have stay open (jar) you may have defrost problem
My automatic icemaker has suddenly stopped making ice. Can you suggest the possible problem.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
2answers
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
1helpful
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Ice-maker is not working. Water dispenser works fine. Ice-maker lock is off. Refrigerator is 1.5 years old. It has been working fine up to a week or so ago. Have not used much ice, recently. Ice...
You need a new ice maker in this unit. This is a very simple repair to perform. You will just need to provide us with your brand and model number so we be sure to get the correct parts for your specific unit.
We also are able to provide parts removal/installation instructions for folks that choose to fix their own.
We look forward to working with you and hope you have a great evening.
Problems with Maytag 21 cu.ft. Top Mount Refrigerator, MTF2172HR
not nessecarily an electrical fire, but sounds as if the compressor is struggling to start, it is indeed "tripping off" on overload. so yo may start ot see a decline in refrigeration. check your manual for "sealed system" coverage. adn check that against our date of purchase, you should have 5 yr manufactuere warr, but that all changed Jan '06 coverage was reduced to one year! yo ucan try replacing teh overlaod relay, atached ot the side of the compressor if youd like
2answers
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
