Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
SOURCE: some fonts are printing in bold
Try replacing your Print Driver on the computer. Think of printers as dumb beasts. They only do things as they are told.
SOURCE: won't print black
Go to the following link and follow the instructions.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00409846&rule=29127&product=439491&printable=yes&encodeUrl=true&
Please let me know what happens, Thank you, Binary Bob
SOURCE: printer wont print what I want only mixed up words on top of page
With the printer on, pull the power plug out of the wall socket. Then power off your PC.
Wait a minute, then plug the printer power cord back into the wall. Turn the printer on, wait a minute, then power up your PC. It should print normally again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: im trying to print a document in word thats about
Alrite now, firstly, since you need only 4 pages of the 200pg document, go to File > Print > Select page range (e.g. 1-4, 51-54, etc)
Then print and make sure you have pages loaded in tray 1.
You can also have papers in tray 2. If MS Word does not respond, then change the drivers to UPD (http://www.hp.com/go/upd), the system may have legacy drivers or An earlier version of firmware.
Rgds,
Nikhil
