How do I replace the trimmer line?
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
HOW DO I CHANGE THE LINE
I have Ryobi 137R trimmer, how do I replace the trimmer line?
how do I replace the line in a trimmer plus
replace the line?
how to load the line in my RYOBI 132r grass trimmer?
how do i replace the trim line on the ryobi trimmer plus 132r?
how do I replace trimmer line?
How to rewind ryobi rlt0350 Electric line trimmer
trimmer line replacement
