What is wrong with it and can it be fixed or do i need a new vcr
SOURCE: Doesn't repond to buttons and stuck on rewind
... The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and abort process. Non-real time tape counters usually get their pulses from this same sensor. Real time counters operate off of the A/C head control pulses and therefore would not be affected by a defective reel sensor). Some older VCRs used a belt driven counter - the belt may have broken or fallen off. Most newer VCRs use an optical sensor which may simply be dirty. See the section on: "Reel rotation sensors". 2. The roller guides are getting hung up and not fully loading the tape either as a result of an obstruction or dried up grease, or a slipping tape loading belt (often accompanied by an spine tingling squeal). Parts may have broken or fallen off of the roller guide assemblies preventing them from fully engaging the 'V-stoppers'. A similar fault may prevent the capstan from fully engaging against the tape d pinch roller. 3. The mode switch sensor is dirty or defective and confusing the poor microcomputer as to the position of the loading mechanism. In this case, the loading process may stop half way, pause, and then unload as in (1) or (2), above. Or, it may do almost anything. See the section on: "Erratic behavior in various modes". 4. Some other condition such as the end-of-tape sensor thinking that you are at the end of the tape is aborting the tape loading process. This might be indicated by a sudden reversal and shutdown rather than a pause (usually accompanied by the sound of a motor whirring) at some point attempting to complete part of the cycle. For problems with record in particular, the record protect tab switch may be dirty or worn resulting in random aborts. 5. Electronic problems like bad grounds or other bad connections are alos possible. Since with some models, (a number of JVC manufactured VCRs, for example) ground integrity is via screws through the mainboard, should these loosen, erratic behavior may result. Tighten the screws. 6. A defective microcontroller or other logic could also be at fault but this is less likely than any of the preceding.
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
SOURCE: video tape won't move
Its a trash tape is glued itself and there is nothing you can do.Maybe but maybe you can try to disasembly the cassete and manualy rotate the wheels but this is not recomanded you can damage video head by using this tape
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
