HELP!!! I have a regular sd 4GB card -- it's formated correctly FAT..., I have the USB cable to connect the phone to my computer and it says that it recognizes the device when connected and then says... looking for folders to sync but nothing happens... how do I get this darn thing to work... main reason I got this phone...:-)
SOURCE: LG Vu CU920
i think you type the code in 0000 (zeroes) and there ya go. [: i went to att.com and typed in puk code and then it said type in 0000 so, hope that helped!
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
SOURCE: LG VU CU920 Sync Software
My wife had the same problem with sync. Our reasoning is to unlock and theme the phone (iphone theme, etc.), but i found the right way to sync and do pretty much anything else. Open up two internet tabs. 1st is for youtube.com (search LG Vu themes), 2nd tab is for lg-vu.com . There is a guy on here who will walk you through LG pc suite , bitpim, and EIP. Use his video and these tools to follow along, and you will be finally able to manage your Vu the way you should. Sad that LG does this to its customers, but i hope this helps you guys feel better. PS: you need to buy a usb data cable for this stuff. Good Luck and enjoy!
SOURCE: unlock code for lg vu cu920
Nope.
Try first calling the manufacturer to get the subsidy code.
If you do not want to call the manufacturer , then try the method on link below, but it does not work on all cu920:
Subsidy unlock instructions for the cu920
SOURCE: Security code for my LG Vu cu920
You can either try 1234...or the last 4 digets of your cell phone number.
every time i try to sync the music it says error and it doesent i tried to fix it everything it told me and it just dosent work
